How to (easily) deny access for bucket containing secure data ?
We created log bucket for secure data + Allow policy for special group - but probably because of default policy “Storage Logs Read” - anyboddy still can access those logs.
Cannot find any example in Docs.
Is there any easy solution ? Or do we need to DENY access from other groups ??
BR, Josef
Hi @josef_solnicky
PFA Dynatrace Resource that contains answer to the related storage policy:
BR,
Peter
@josef_solnicky,
This is my usual strategy among my clients, but I’m also open to new ideas:
  1. Logs for each group/application goes into certain buckets.
  2. No one has access to global logs (yeah, except adminns)
  3. I give the following minimal policies to each group. Of course, you can add other functionalities, but this is the bare minimum I’ve got working. I still have to work on hardening the last two lines. Please notice you have to define the condition for storage:logs:read
    ALLOW app-engine:apps:run WHERE shared:app-id = “dynatrace.classic.logs.events”;
    ALLOW app-engine:apps:run WHERE shared:app-id = “dynatrace.notebooks”;
    ALLOW app-engine:apps:run WHERE shared:app-id = “dynatrace.logs”;
    ALLOW storage:buckets:read WHERE storage:bucket-name = “special_bucket”;
    ALLOW storage:logs:read WHERE storage:k8s.cluster.name = “special_k8s”;
    ALLOW document:environment-shares:read;
    ALLOW state:app-states:read, state:app-states:write, state:app-states:delete, state:user-app-states:read, state:user-app-states:write, state:user-app-states:delete, state-management:app-states:delete, state-management:user-app-states:delete, state-management:user-app-states:delete-all, app-settings:objects:read, app-settings:objects:write;
    ALLOW document:documents:read, document:documents:write, document:documents:delete, document:environment-shares:read, document:environment-shares:write, document:environment-shares:claim, document:environment-shares:delete, document:direct-shares:read, document:direct-shares:write, document:direct-shares:delete, document:trash.documents:read, document:trash.documents:restore, document:trash.documents:delete;
Thanks @AntonioSousa for detailed description.
Thank you Antonio !
Trying to implement it in first case - in fact just the log part now
Plus removing the “Read Logs” and “Environment role - View logs” policies.
BR, Josef
Hi Antonio,
how you are defining access to PARTICULAR standard entities and metrics - hosts, processes, services, requests, traces, apps, user actions ? Via policy boundaries ?
Are you still using management zones ?
BR, Josef
Josef, did you find solution for that? I am currently trying to figure out what is the best way to control access to entities and data in Kubernetes, Problems and Logs application.
I believe this is a very common use case, yet I haven’t been able to find any good examples!
