Overview: We have recently installed Dynatrace OneAgent into some .Net Framework Azure App Services. These services communicate with external partners that use various technologies, including SOAP XML. For outbound SOAP requests, Dynatrace injects a SOAP header X-dynaTrace, like the following: “<X-dynaTrace xmlns=http://ns.dynatrace.com/wcf xmlns:s=http://schemas.xmlsoap.org/soap/envelope/\>…</X-dynaTrace>”
Problem: We have 1 or more external partners whose SOAP services throw an error when receiving a header that they don’t recognize, and this includes the X-dynaTrace header. There could be many more partners using similar technology, we really don’t know without trial and error, which would be painful for ourselves and our partners.
Current Workaround: We have uninstalled the Dynatrace OneAgent from our azure app service which makes outbound calls to customer services. This is not ideal, as we do not have monitoring of this service.
What We Want: We would like to be able to have OneAgent installed and active in the affected azure app service, but not add the X-dynaTrace header tag to outbound external SOAP request. We would be happy to hear about other possible solutions that may be available too, such as: a) Don’t add the XML SOAP header tag to any SOAP requests; this wouldn’t be ideal, but at least we could use Dynatrace and have fully populated distributed traces for non-SOAP. b) Disable addition of the custom XML SOAP header for specific domains. c) Disable the XML SOAP header globally, but have explicit inclusions of certain domains or endpoints. d) Other…
We do have a support ticket open, but it’s been a bit so I thought I would ask the community too. Thanks for your time.
