How to enable failure notifications when a workflow has failed ?
Is there an option to monitor the Workflows and trigger a notification when the workflow is failed due to some reason ?
Ram.
Sure there is! Just turn on workflow notifications, see more at Get notified about workflow changes — Dynatrace Docs
Hi @Julius_Loman
Thanks. Is it possible to trigger problem alerts only during the workflow failures but not for Edits, etc ?
