To ensure successful instrumentation of your Python application with OneAgent, follow these essential configuration steps:
1. Enable Python Monitoring
Navigate to:
Settings → Monitoring → Monitored technologies → Python
Make sure the “Monitor Python” option is enabled.
2. Enable Your Python Framework
If you’re using a specific framework like FastAPI, ensure it’s enabled under:
Settings → Preferences → OneAgent Features
Look for “Python FastAPI [Opt-In]” and enable it.
3. Enable Process Group Monitoring
Go to:
Settings → Processes and containers → Process group monitoring
Ensure automatic deep monitoring is enabled.
4. [optional] Set Custom Monitoring Rules (not needed if running in container)
If your application isn’t automatically detected, define a custom rule:
Settings → Processes and containers → Custom process monitoring rules
This helps Dynatrace identify and monitor your Python processes correctly.
5. [optional] Special Note for PaaS Installations (Pre-1.315)
For PaaS setups using OneAgent versions prior to 1.315, manual configuration is required.
In the ruxitagentproc.conf file, add:
[agentType]<br>python on<br><br>[general]<br>pythonInjection on
Example Dockerfile Snippet:
# Install Dynatrace OneAgent<br>COPY --from=tenant.live.dynatrace.com/linux/oneagent-codemodules:python / /<br>ENV LD_PRELOAD /opt/dynatrace/oneagent/agent/lib64/liboneagentproc.so<br>ENV DT_AGENTTYPE_OVERRIDE python=on<br><br># Append Python settings to ruxitagentproc.conf<br>RUN echo -e "[agentType]\npython on\n\n[general]\npythonInjection on" >> /opt/ruxitagentproc.conf
Python version
Please make sure that you are using supported python version CPython 3.8-3.13 List of supported python frameworks here: Technology support — Dynatrace Docs
For further informations about python module please see our documentation here: Python — Dynatrace Docs
