How to encrypt a test password used for synthetic monitors?
We are using Monaco CLI to add synthetic browser monitoring and deploy them to environments. One of the browser monitors is to login into an application with a test username and test password. Dynatrace doesn’t allow test passwords and is looking for them to be encrypted. How to encrypt the test password that is acceptable by the synthetic monitor?
@sirishav,
Are you using the Vault?
Yes, as @AntonioSousa suggest here you can found the documentation.
