I have a calculated metric for a series of nodes (in this case % memory used) - I would like to show a table of matching nodes where the calculated value is less than 20% or greater than 80%. I’ve got the first part working but I am unsure if filter will allow me to produce what’s needed.
builtin:kubernetes.container.requests_memory:last:splitBy("dt.entity.kubernetes_container","dt.entity.kubernetes_cluster"):sum
/ builtin:kubernetes.container.memory_allocatable:last:splitBy("dt.entity.kubernetes_container","dt.entity.kubernetes_cluster"):sum*100):setUnit(Percent):sort(value(sum,descending))
