How to extract a dashboard contents to .csv?
We have a dashboard that contains tabular form of disk available % of all the disks of a client, when tried to extract only JSON is available that too - webpage JSON is extractable but not the contents which are in table.
Hi @Pranav1,
Check out the accepted answer in this similar question: Dashboard - fetch data in CSV or Excel format
A few options
1.) Use Dynatrace Power Ups GitHub - dynatrace-oss/DynatraceDashboardPowerups: Chrome Extension to boost DT dashboards · GitHub
2.) I have exported to json then used a web tool to export to excel JSON To CSV Converter
3.) Use old charts
