Customer asks to monitor OPEN APIC with synthetic so we create http checks with token saved in the vault.
The issue here is that the tokens got only 10 hours lifetime and we need to generate a new token with rest api every hour.
Our intension now is to call the rest api that generate the token on OPEN APIC and with value from the response body to set a value (with api.setValue(key, value)) for the next step which will send dynatrace vault rest api to change the value of the token to the new one.
We need your help here with how to extract values from response body in the post execution step with response.getResponseBody() , how can we extract a value after token=" till the next " from the response body?
As the response body is a string, I’d say using a regex match would do the trick, with a capture group somewhat like this (adapt it to the format of your token of course):
