How to figure out tenant version
Any ideas how to figure out Dynatrace tenant version in SaaS environment? (Not in Dynatrace managed).
Oneagent version available from the tenant can be seen by navigating to Settings->Preferences->Oneagent updates or when deploying new agent, but I can’t see the tenant version anywhere.
Hi, what do you mean by tenant version? Tenant is just an environment for agents that are versioned.
By tenant I mean the version of my dynatrace environment - what version is running at my https://xxxx.live.dynatrace.com .
I was about to try the Golang support, but I can’t see the option in my environment. Blog post says it is from the cluster version 127. How can I see if my environment is at this level?
Briefly looking at the HTML source code - it should be 127, since some URLs include this numbering, but I don’t see the Golang support in our environment.
OK. I see. So in SaaS all clusters are already on 1.127. You can not bother that at all if you are SaaS user. We perform all cluster updates in time.
It seems that this feature was not enabled yet for your tenant. Please give us some time, and we’ll enable that shortly.
Hey Julius, I’ve just received a confirmation this is going to be available on Friday.
Thanks for your interest in willing to test that. Let us know your impressions and insights you discovered with that new functionality!
With recent sprints (probably from 146) the tenant version is visible in the bottom of the user menu. No need to look at the source code anymore.
I still cant see the SaaS version in the UI? Can you please help with the right navigation to see the same
SaaS Version
Great, thank you
Where we can see it with the new Dynatrace view?
@Duran_Narbona it’s not (yet) in the new platform UI but it will be available shortly in the next releases with additional improvements. You can switch to the old UI to get the version.
You can see the tenant version if you go to the Hub> Manage > any Classic App, e.g Data Explorer
Have there been any updates on this? The team would love to check the version without going through the Hub or switching to the old UI
Same here, it would be great show in a dashboard the actual version.
You can add a code tile with this code on a new dashboard to display the current version of the server
import { clusterVersionClient, deploymentClient } from "@dynatrace-sdk/client-classic-environment-v1";
export default async function() {
    let clusterVersion = await clusterVersionClient.getVersion();
    console.log(clusterVersion)
    return clusterVersion.version;
Same as this API :
Great, just what I was looking for. Thank you.
Does anyone know the latest on this? Where can the version be found these days?
Did you see below?
Hub has it and there is code below to put in a notebook or dashboard
This is awesome!!!
Hi @Julius_Loman I leave you an Idea I have created with this point.
