How to filter OpenTelemetry array attributes in OpenPipeline Dynamic Routing?
Hi everyone,
I’m looking for some guidance regarding OpenPipeline Dynamic Routing and filtering OpenTelemetry array attributes.
I receive log records containing an attribute that is stored as an array, for example:
  • [“1”, “2”]
  • [“1”]
  • [“2”]
  • and potentially other values as well.  ( equal or not equal )
My goal is to create routing rules based on the content of this array. However, I noticed that in the Dynamic Routing matcher, the array() function is not available and any expression using it returns the following error:
Invalid matching condition. The function `array()` isn’t enabled.
Because of this limitation, I haven’t found a way to validate whether an array contains a specific value or to compare it against a list of expected values.
Has anyone successfully filtered OpenTelemetry array attributes in OpenPipeline Dynamic Routing?
For example:
  • Route logs when the array contains “1”
  • Route logs when the array contains “2”
  • Route logs when the array contains either “1” and “2”
Are there any supported functions, workarounds, transformations, or best practices to achieve this?
Thanks in advance for any suggestions!
@Carl_Me  matchesValue or matchesPhrase will work on arrays too. DQL matcher in OpenPipeline — Dynatrace Docs
  • Route logs when the array contains “1” - matchesValue(myattribute, “1”)
  • Route logs when the array contains “2” - matchesValue(myattribute, “2”)
  • Route logs when the array contains either “1” and “2” - matchesValue(myattribute, “1”) and matchesValue(myattribute, “2”)
