How can I force alerts to be enabled when an extension is deployed or updated?
I followed this documentation to extract the alert in JSON format:
I tried this but it does not work :{“id”: “XXXXX”,“metricSelector”: “XXXXX”,“name”: “XXX”,“description”: “XXX”,“severity”: “AVAILABILITY”,“enabled”: true,[…]*}*Thanks.Julien
As far as I know we always ship them disabled to allow customers to enable it at will, rather than causing new problems which they didn’t set up any routing for or other rules.
A side-effect is that the customer (or the partner ) doesn’t realize that he’s disabling alerts when he upgrades his extension. It almost becomes good practice to create the alert independently of the extension. What do you recommend?
