How to generate environment.yaml file for downloading config using Monaco
I am fairly new to DT and need help on API token mentioned in environment.yaml file, I am trying to configure Monaco and would like to know how to generate this please
You have more than one way to do it but one example would be:
name_environment:
    - name: “name”
    - env-url: "https://{environmentid}.live.dynatrace.com "
    - env-token-name: “API_TOKEN”
And you can execute “monaco download -e environments.yaml” to download entire environment configuration or “monaco download -e environments.yaml --specific-api some_api” to download specific API.
Best regards
Hi @Tanveer,
For token generation, yellow roles are the minimum, red is a wider sope.
Some documentaiton about the required token roles:
Deploy your first configuration | Dynatrace Docs
Configuration types and token permissions | Monaco (dynatrace.github.io)
I hope it helps.
Best regards,
Mizső
Many thanks Mizso, this is what I was looking for
I have followed this Install Dynatrace Configuration as Code via Monaco — Dynatrace Docs and getting below error while running monaco.exe
@Tanveer I am not sure if you referred this documentation
https://dynatrace.github.io/dynatrace-configuration-as-code/commands/downloading-configuration
  1. Enable CLI 2.0 by adding an environment variable called NEW_CLI with a non-empty value other than 0.
export NEW_CLI=1
I think this should solve your problem
Or “$env:NEW_CLI=1” if you are in powershell / Windows.
Best regards
Hi @Tanveer,
Instead v1 use the v2 and you do not need to deal with CLI configuration. (and v2 has an official support comapared v1).
Then you can run this command:
monaco download manifest manifest.yaml your_environment
I hope it helps.
Best regards,
Mizső
