How to get Hung Thread Metrics using JMX Extension
Hi
I’m new to Dynatrace, can you please tell me how to get the Hung Thread Metrics for the Application using JMX Extension? Because I’m not able to find it, I can only see the following thread metrics in java.lang domain
CurrentThreadCpuTime
CurrentThreadUserTime
DaemonThreadCount
PeakThreadCount
ThreadCount
TotalStartedThreadCount
Actually, I want the hung thread metrics for the alerting process. When the Application Hung Thread Count goes above 8, then the dynatrace will trigger a mail.
Hi @Beginner the best description for use JMX extensions could be found here. After that you need to setup an alerting profile, a problem notification and a metric event to trigger the mail.
