How to monitor services for HASHICORP
As I remember those processes are native so they cannot be monitored transactional.
Those services have API endpoints where they push their metrics for monitoring or they can push the metrics directly. The best way would be to write a OneAgent plugin to collect them. At the moment there is not a publicly available OneAgent plugin to collect those metrics since Dynatrace is investing into broader scope of infrastructure monitoring, there might be some early versions of them.
It would be very nice to have an out of the box of Hashicorp Vault monitoring. Other competitor have it ![]()
I don’t want to spend time to write custom plugin ![]()
Alex
The API DOC is @ /sys/health - HTTP API | Vault by HashiCorp (vaultproject.io)
Hi all,
It should be possible to send Vault and Consul monitoring data into Dynatrace:
- It is possible to integrate the Dynatrace OneAgent with StatsD, Telegraf and Prometheus
- HashiCorp provides a way to monitor Vault and Consul with Telegraf
Sia
Monitoring HashiCorp Consul is now available, here are some useful blog articles about the topic:
Automatic intelligent observability into your HashiCorp Consul service mesh
Manage your monitoring as code with Dynatrace’s HashiCorp Terraform integration
