How to grant full control privileges to a tenant admin on a dedicated environment
How to provide the admin privileges to a tenant admin to configure custom metrics, set up alerts, or enable RUM on the dashboards for both the backend and frontend applications.
A basic starting point would be using Dynatrace default groups.
But more granulity can be done using policies also.
Best regards
I need to provide a tenant admin user who can configure custom metrics, set up alerts, and enable RUM on the dashboards for both our backend and frontend applications. Currently, when they attempt to configure these settings, they are prompted for Global admin privileges.
To maintain security and prevent the same admin view from being visible across other tenants, I want to ensure the user has the appropriate permissions without granting full global admin access.
Could you please assist in creating or configuring a tenant-specific admin user with the necessary permissions?
Thanks in advance for your help.
Best regards,
Then, I will suggest you Working with policies.
Best regards
Hi @Cliffordwilban
The request seems simple, but it could be complex.
Dynatrace is working for best practices for roles and permissions; this will be available soon for a public.
But know, I recommend reviewing more information about permissions.
Here : Manage users, groups, and permissions — Dynatrace Docs
Or use the default groups that best suit your needs.
I hope it’s helpful :flexed_biceps:
