We are seeing that on a subset of our servers, a specific process is generating a very large number of log records containing a specific keyword “bypass”.
How would I produce a list/chart of only the servers that have reported an average of more than 1000 lines/hour containing this keyword, and the total # of log lines with the keyword, over the past 5 days?
Note that this does not provide an average of lines/hr, but the total count of lines with “bypass” per host within your selected timeframe. Naturally, the Hosts with more lines per hour will still very likely rank higher on the list of total count. So this can still be used to identify the list of servers exhibiting this specific high-volume logging behavior.
And keep in mind that, on Notebooks, you can always make use of the timeframe selector to adjust to your needs and specific hours:
(I used last 2 hours)
Lastly, if you’re planning on having a dashboard with this query it might be worth to look into bucket assignment and optimize the query to look into specific buckets.
Thanks for your suggestion. I’ve updated the query a bit, as I want to calculate the percentage of log lines containing the specific keyword that come from one executable. Unfortunately, the new column I’m adding with fieldsAdd does not appear to function as I expect - I always get a 0 in the column.
Here is my current query:
Hey @Aaron_L ,
One thing to keep in mind is that in Dynatrace Query Language the division between two integer values is an integer, which gets rid of any decimal portion.
Easy straightforward solution to this is just to cast both variabels to double:
Thanks for the quick response. The toDouble() option worked well, and like the *1.0 option, it’s only required on one of the variables to convert the result to floating point. Problem solved!
As I get a bit more experience with DQL, I may come back to the original problem of calculating average lines/hr, but this will do for now.
