How to integrate Dynatrace with Mulesoft?
Are there plans to integrate with Mulesoft Anypoint MQ, so we can get metrics on queue depths?
There are no plans at this point, although we can work with you on a custom engagement to create an extension, if interested please reach out to extensions@dynatrace.com
There is definitely a biiiig opportunity for Anypoint MQ support. Their native observability is objectively bad.
Is this extension for the on-prem version?
Hi I’ve use it on both SaaS and OnPrem @svenkit
Thanks. So, my client is using MuleSoft 4.3 on AWS servers and doesn’t have Anypoint Cloud Hub in their landscape. Client is asking whether the v2 extension will work in that scenario.
Hi @svenkit I don’t think you could use it in that scenario because when you configure it you only have this options:
Mulesoft has several dozen products, the extension is only for Mulesoft Cloudhub. Which product are they running on AWS? Can you install the OneAgent there?
I know this is an older post, but does anyone have Dynatrace working with MuleSoft RTF running on prem?
Hi, @johnroncaglione the extension works with Anypoint not RTF, both on prem and SaaS.
This is how mule works by default,
I found that we can trace an “exceptions”
Dev team looking for customisation exceptions classes.
In this case it will be possible to filter exception types in multidimansional charts in the same way like http codes.
@DanielS thanks for confirming the extension.
Has anyone successfully used the OneAgent on MuleSoft RTF servers?  When we have tried, the agent causes issues with MuleSoft.
Hello, @david_lopes Are upcoming versions or current version of the extension compatible with Anypoint Mulesoft Cloudhub 2.0?
@AntonioSousa
No, the metric storage is different for 2.0.
We are actively looking for customers that want to collaborate on improving this extension, we need access to their environments to assess how to implement this support.
You can count on me :grin:
Ditto- more than happy to offer my enviro! We are the 2nd largest customer on CH2.
Hi all, I have a problem with the mulesoft extension, we can’t see which internal host it talks to. we have mulesoft in the cloud, how can we see the interaction with our verticals?? help.
Helllo @administ25 you can select the ActiveGate group from where the extension runs. Inside the AG group you can have one server only.
Hi @david_lopes
For clarity, is this improvement for the Cloudhub extension expected to support v2.0?
Hello, I am new to Dynatrace and have a requirement to integrate Mulesoft RTF with Dynatrace. MuleSoft RTF is running on Azure Linux VMs (VN/bare metal model). Is it possible to do that?
