Dear colleagues, I share a link with and exhaustive detail to integrate distributed trace info from Mulesoft into Dynatrace via Open Telemetry. The following image is an abstract of the link.
Hope it helps.
Hope it helps.
Great Tip @DanielS
Hi Daniel,
Do you have any real experience with getting logs from Mulesoft into Dynatrace? This is what the customer expects.
We are currently using this extension: https://www.dynatrace.com/hub/detail/mulesoft-cloudhub-extension-v2/?query=mul&filter=all
Hello @jiri_stefanek what you need to use is the Dynatrace Open Telemetry Collector to collect metrics or logs. See the Logger Message Processor Output section in the article from my original post. Initially I do it for traces.
