How to integrate Synthetic Monitoring with Dynatrace SaaS
I am exploring all the possibilities to integrate Synthetic Monitoring with Dynatrace. I have generated a token for Synthetic Integration. When I try to pass the API token within an authorization header Its giving me below error:
{“error”:{“code”:404,“message”:“failed to resolve tenant <23936>”}}
Can some one help me how to resolve this?
Was the feature turned on for your tenant? At the moment this feature is in closed beta status and needs to be turned on for your environment. Best would be to contact your Dynatrace contact in order to get in touch with one of the product managers.
Does (will) this feature work for Managed? I noticed the UI says “Dynatrace SaaS integration”.
Yes, it will also work for Managed.
Is this still in beta and needs to be turned on?
(running Dynatrace Managed version Version 1.132.87.20171117-162916)
I am getting failed to resolve tenant 10 error using Postman any idea how to resolve.
Hi Naveen,
please can you contact chat and explain what you are trying to do? They should be able to help. This feature was for integrating Classic Synthetic Monitoring with Dynatrace Synthetic. Classic Synthetic monitoring has been end of life for sometime now.
If you are trying to push third party monitor data to Dynatrace you can find further information on that API here
