How to monitor CPU usage by container in DQL?
Using the following DQL, I can get the names of containers in a container group:
fetch dt.entity.container_group_instance
| filter id == "CONTAINER_GROUP_INSTANCE-XXXXXXXXXX"
| fieldsAdd containerNames
| expand containerNames
I can also get the CPU usage user time of the container group instance in DQL:
timeseries { usage_user_time = avg(dt.containers.cpu.usage_user_time) }, filter: { dt.entity.container_group_instance == "CONTAINER_GROUP_INSTANCE-XXXXXXXXXX" }
Is there a way in DQL to get this metric by container?
@jmarbaix If its the CPU usage you are after , you can try the below
timeseries avg(dt.kubernetes.container.cpu_usage),
by: { k8s.container.name, dt.entity.container_group_instance },
filter: { matchesValue(dt.entity.container_group_instance, "CONTAINER_GROUP_INSTANCE-xxxx") }
| fieldsAdd dt.entity.container_group_instance.name = entityName(dt.entity.container_group_instance)
If its “dt.containers.cpu.usage_user_time” metric, then
timeseries avg(dt.containers.cpu.usage_user_time),
filter: { matchesValue(dt.entity.container_group_instance, "CONTAINER_GROUP_INSTANCE-xxx") }
We are not using k8s containers, but podman containers, so sadly enough your proposed solution doesn’t work.
@jmarbaix I think the second query should still be good with some modifications as its a container metric, can you please try below?
timeseries avg(dt.containers.cpu.usage_user_time), by: { dt.entity.container_group_instance },
filter: { matchesValue(dt.entity.container_group_instance, "CONTAINER_GROUP_INSTANCE-XXXX") }
Hi @jmarbaix ,
The easiest way is to go to the Dynatrace UI, select the container for which you want to get the metric, open Data Explorer from there, and then open a notebook. This will show you the DQL running behind the scenes.
From there, you can adjust the query according to your needs.
Hope this helps?
