Hello everyone,
In Dynatrace Managed, how can I view detailed information about user access—such as which users have logged in, how long they stayed, what actions they performed, how many times they accessed the system, etc.?
Is there a specific tool for this purpose? Can it be integrated with something else to get more detailed insights? Or is there an easier way to do it?
When I check through the Cluster Management UI, I can only see who logged in, but I need more comprehensive details.
Has anyone done this before? Any advice would be greatly appreciated.
Thank you very much for your support!
Some of the data is available in the Lens adoption, currently the view is limited (it was a better report). Please reach out to your CSM contact. The adoption report is based on RUM which gets injected with OneAgent to Dynatrace UI pages. However, the agent reports to Dynatrace, so you don’t have direct acess to raw data.
If you want to create the report on your own, I’d recommend the NGINX access log on Managed cluster nodes for more detailed data and audit log. But it might be a long journey.
Thank you very much for your response.
It’s possible that I may have misunderstood you earlier, so I would like to clarify my request. I have granted access profiles to several users for Dynatrace, and these users log in throughout the day to perform monitoring tasks or carry out their daily activities within Dynatrace.
What I would like to know is: which users accessed Dynatrace during the day, what actions they performed, and get a comprehensive view of all their activities.
The audit log files on the Dynatrace nodes are not very user-friendly to read, and the information available under Cluster Management → Events is quite limited — it mainly shows who logged in successfully or failed to log in.
However, I’m looking for more detailed insights.
Could you assist with this? Or perhaps suggest an integration or alternative method to achieve this?
So basically, you want to track what individual users of your Managed instance are using and where they spend time.
Some of the data is available in https://myaccount.dynatrace.com portal in the Adoption report:
The report used to have user IDs and individual reports, but it has been removed (probably for compliance reasons). If you need any detailed reports, I strongly suggest reaching out to your Dynatrace Customer Success Manager or Account Manager.
Access logs are great source, but they don’t contain user ids. Audit logs have only info about changes and logins.
What can be considered is to opt out from the selfmonitoring OneAgent deployment on the Cluster nodes, and deploy your own OneAgent reporting to one of your Managed environments. Configure RUM and get the data. It will cost you licences (host units/host gibihours for agents, DEM / user sessions for sessions), but it will give you options to get the data you need. But I’d recommend doing it as last resort - when you won’t be able to get the data from Dynatrace directly.
Hello guys,
I agree with @HuseynNajafli , the audit Logs aren’t user friendly, that’s why I submitted this Product Idea (Improved accessibility and visibility of Audit Logs - Dynatrace Community), you can check if make sense, if yes give a Kudo please
Thx,
Maximiliano Lopes
If you have a different logging tool, you can alternatively transfer the logs there and analyze them.
Linux defaults for log files in Dynatrace:
But I agree with @HuseynNajafli and @MaximilianoML , it is not user-friendly and even without Grail, it should be easier to analyze the Dynatrace logs. If you need a different logging tool for this (depending on the company you work for, it may be required that audit and other logs from such systems are stored separately), documentation on the individual log files per role (cluster node and others) would also be very helpful, possibly with information on which logging source type standard is used (If it is documented, I can’t find it and would be grateful if someone could provide me with the URL).
Greetings,
Urs
you can use this powershell script:
param(
[int]$HoursBack = 14
$headers = @{
"accept" = "application/json; charset=utf-8"
"Authorization" = "Api-Token dt0c01.xxxxx.xxxxxxxxx"
$uri = "https://dynatrace.com/e/tenant/api/v2/auditlogs?to=now-${HoursBack}h&sort=-timestamp"
# GET
$response = Invoke-RestMethod -Uri $uri -Method Get -Headers $headers
# List of user to ignore
$ignoreList = @("OnPremLogStorageLicenseWorker", "Session management", "Min ActiveGate version auto-adjustment service", "SyntheticTokenProviderWorker", "settings conversion migration", "Cloud service metric registration", "Min Agent Version Adjustment Worker" )
# Filtering, removing duplicates and preparing a user list
$users = $response.auditLogs.user |
Where-Object { $_ -notIn $ignoreList } |
Select-Object -Unique
# Create file
$fileContent = @(
"Number of people using Dynatrace in the last $HoursBack hours: $($users.Count)",
"List below:"
$fileContent += $users
# Save to file
$fileContent | Out-File -FilePath "users.txt"
# Info
Write-Output "Result save in file users.txt"
Or a bash script that will retrieve login data and send it as metrics to Dynatrace. You’ll be able to display this data in a table.
#!/bin/bash
# Dynatrace API configuration
GET_API_URL_PROD="https://dynatrace.com/e/tenant/api/v2/auditlogs?to=now-22h&sort=-timestamp"
GET_API_URL_PREP="https://dynatrace.com/e/tenant2/api/v2/auditlogs?to=now-2h&sort=-timestamp"
POST_API_URL="https://dynatrace.com/e/tenant_where_u_want_to_send_metrics/api/v2/metrics/ingest"
API_TOKEN_PROD="dt0c01.xxxxxxxxxxx"
API_TOKEN_PREP="dt0c01.xxxxxxxxxxxxxxxx"
# Function: Retrieve and group the number of logins
get_logins() {
local url=$1
local token=$2
local env=$3
curl -s -X GET "$url" \
-H "accept: application/json; charset=utf-8" \
-H "Authorization: Api-Token $token" |
jq -r --arg env "$env" '
.auditLogs
| map(select(.eventType == "LOGIN" and .success == true))
| group_by(.user)
| map({
user: .[0].user,
count: length
| "number_of_logins_\($env),user=\(.user) \(.count)"
# Function: Send single metric
send_metric() {
local payload=$1
echo "Send: $payload"
curl -s -X POST "$POST_API_URL" \
-H "Authorization: Api-Token $API_TOKEN_PROD" \
-H "Content-Type: text/plain; charset=utf-8" \
--data "$payload"
# --- Execution ---
# 1. Logins Env1
logins_prod=$(get_logins "$GET_API_URL_PROD" "$API_TOKEN_PROD" "prod")
if [[ -n "$logins_prod" ]]; then
while read -r line; do
send_metric "$line"
done <<< "$logins_prod"
else
echo "No logins for env1"
fi
# 2. Logins Env2
logins_prep=$(get_logins "$GET_API_URL_PREP" "$API_TOKEN_PREP" "prep")
if [[ -n "$logins_prep" ]]; then
send_metric "$line"
done <<< "$logins_prep"
else
echo "No logins for env2"
fi
