My requirement is to monitor a file in a Linux server which is daily created between 6:30 am and 6.40 am.
This means, daily a new file will be generated at 06:30 am. How to monitor this using a file system monitoring extension?
Dharini
Dharini
Hi @dhariniu , good day.
One option is you to use the metric filechecker.files_age, to alert if file age is higher than 24h (86400 seconds).
So, if the file is not updated/created in 24h (daily) you will get an alert.
Try and let us know.
