Summary
Browser Clickpath Synthetic Monitors in Dynatrace validate end-user journeys by recording clicks and keystrokes. However, some web applications depend on keyboard inputs (such as Enter, Escape, arrow keys, or function keys) that the Dynatrace Synthetic Recorder doesn’t capture.
This article explains how to simulate keypress actions in a Browser Clickpath Synthetic Monitor using JavaScript synthetic events, enabling reliable monitoring of applications that rely on keyboard input.
Problem
The Dynatrace Synthetic Recorder doesn’t capture keyboard‑only interactions such as:
- Pressing Enter or Escape
- Navigating menus with arrow keys
- Triggering actions with function keys
As a result, Browser Clickpath Synthetic Monitors may fail or behave unexpectedly when replaying user journeys that require these keypresses, even though the application works correctly for real users.
Troubleshooting steps
Before implementing a solution, confirm the following:
- The failing step in the Browser Clickpath Monitor requires a keyboard action rather than a mouse click.
- The keypress is:
- Global (not tied to a specific element), or
- Associated with a specific input or UI element.
- You know the key code for the required keypress (for example, Enter, Escape, F-keys, arrow keys).
If these conditions are true, handle the interaction using a JavaScript synthetic event instead of a recorded step.
Resolution
To perform a keypress in a Browser Clickpath Synthetic Monitor, add a JavaScript event that dispatches keyboard events manually:
- Identify the key code for the required keyboard action.
Example: For F7, the code is 118. Find key codes here. - Determine the target element:
Page body: If the keypress isn’t tied to an element, use
bodyvar input = document.querySelector("body"); -
Specific DOM element:
Open the page in Chrome.
Right-click the target element → Inspect.
In Developer Tools, right-click the element → Copy > Copy JS path.
Use that selector in your script
var input = document.querySelector("#yourSelector");
- Update the JavaScript snippet with:
key: The key to press
keyCode: The corresponding key code
input: Either
"body"or the selector
Example:var parameters1 = {isTrusted: true, altKey: false, bubbles: true, cancelBubble: false, cancelable: true, charCode: 0, code: "F7", composed: true, ctrlKey: false, defaultPrevented: true, detail: 0, eventPhase: 0, isComposing: false, key: "F7", keyCode: 118, location: 0, metaKey: false, repeat: false, returnValue: false, shiftKey: false, which: 118}; var parameters2 = { isTrusted: true, altKey: false, bubbles: true, cancelBubble: false, cancelable: true, charCode: 0, code: "F7", composed: true, ctrlKey: false, defaultPrevented: false, detail: 0, eventPhase: 0, isComposing: false, key: "F7", keyCode: 118, location: 0, metaKey: false, repeat: false, returnValue: true, shiftKey: false, which: 118}; var input = document.querySelector("#yourSelector"); input.dispatchEvent(new KeyboardEvent("keydown", parameters1)); input.dispatchEvent(new KeyboardEvent("keyup", parameters2));
- Add this script as a JavaScript step in your Browser Clickpath Synthetic Monitor and position it in the sequence as needed.
What’s Next
If the keypress alone doesn’t resolve the issue:
- Verify if additional events (like focus or input) are required.
- For advanced interaction scenarios, check the guidance on JavaScript events in Browser Clickpath Monitors.
- If problems persist, open a support chat and provide:
- A link to the affected monitor
- Details of the simulated keypress
- Any JavaScript used
Related reading
