How to rename a rule-based tag?
It appears that I can only change the rule associated with the tag, but cannot rename the tag.
Is that correct?
If it is, is there any workaround other create a new tag with the exact same rules, then delete the old one?
Hi Chan,
I do not believe this is possible. Unfortunately, you are going to have to create a new tag with the exact same rules.
NJ
Do you know is there is any product improvement idea to permit it?
This is possible now, via the new Configuration API, currently an EAP.
There is a PUT Endpoint for /autoTags/{id} which updates an existing auto tag.
