I have a requirement where I want to rename few process group instances.
Dynatrace has detected two process groups with same name (DT created two different Process groups because they have different host group names) and those process groups has same process group instances names.
If not you have to insert environment variable at the start of your process and the procedure will vary based on what tech you are using. Here is the link for it:
Then I guess you are near to a solution, if metadata allows you to enrich your process discovery mechanism,
Try it and let us know, but know that for the rule to be applied you’ll need to restart the process itself.
This will discover a process as a new one, not aggregated to the previous process group you had.
In my case (in my org) the adopted hierarchy is:
process group = namespace
|___________>> process istance = full pod name
And reflected it via advanced process detection rule in DT. It is always about finding a common pattern
