Anbu
1
I have set up a JMX/PMI extension for monitoring the JMS connection pool, and I am tracking the following metrics:
- Pool size
- Free pool size
- Waiting time
- Waiting thread count
How can I configure an alert in Dynatrace to notify me when the JMS connection pool is exhausted
lubrman
2
Hi @Anbu
If you are using Dynatrace Managed, the only option is via metric events, where you define the metric and the corresponding threshold.
https://docs.dynatrace.com/managed/discover-dynatrace/platform/davis-ai/anomaly-detection/set-up-a-customized-anomaly-detector/how-to-set-up/metric-events
If you are using Dynatrace SaaS, you have more options. You can use metric events, or alternatively SRG
