Not quite sure if someone has workaround this already? or needs a RFE to be raised?
The reason to get a default color, is it will ease our job in such scenario:
- I got a field that has 9 possible value, if the field is of any value from 2nd value to 8th value, honeycomb needs to be red; if the field is of 1st value, then makes it green.
- Then instead of make 9 rules in the tile’s->visual->color->custom color there, I would just need 1 rule.
Also, in future, customer might have some update that cause the field to has new 10th value, 11th value etc etc…Each of these new value also needs the honeycomb to be in red.
