In Dynatrace, we can setup service availability monitoring. This can be achieved in two ways.
1) Settings--->Monitoring---> OS Service Monitoring
2) Host--->Settings---> OS Service Monitoring
Once we setup the services for monitoring, we can see their status in the Host main page under “OS services analysis”. By default, the service availability alert will go to “Default” alerting profile. To send the service alerts to application/infrastructure owners, please follow the below steps.
Edit the Management Zone of which the hosts are part of.
Add a new Rule---> Rule Type--->Monitored Entity----->Rule Applies To--->Custom Devices---->Add Condition--->property--->Custom Device Name--->Select the right operator--->Value---> Provide the service name---->Preview and make sure you see the service name appears.
You are all set. Now, the service availability alerts will trigger to the Alerting profile which is mapped to this Management zone.
If you don’t want to call out the OS Services you can use the blanket rule for the monitored entities. This assumes you have Host Groups set.
Type(“os:service”), fromRelationships.runsOn(type(“HOST”), tag(“Host Group”))
You can also use entity selectors to choose an OS Service based on its name:
type(os:service),entityName.startsWith("<name of OS service entity>")
host on which OS service is running:
type(os:service),fromRelationship.runsOn(type(HOST),entityName.startsWith("<name of the host>"))
or name of a process, which is associated with the OS service:
type(os:service),toRelationship.runsOn(type(PROCESS_GROUP_INSTANCE),entityName.startsWith("<name of the process entity>"))
Currently OS Services incidents are coming as P2 as it is going to Default Profile. How can we reduce this to P3?,
when you say ‘coming as’ is that in an event manager?
Currently OS service alerts is choosing default problem profile. Hence all OS service alerts is creating as P2 incident in serviceniw. My ask how do we make this slowdown alert, so P3 incident will be created in Servicenow
okay so with your SNOW integration. So the OS Services is built in alerting, so I don’t think your going to be able to change the priority out of the box in Dynatrace. What you can do, is make a custom event rule, this will then allow you to have more flexibility in the way of what the alert classification is etc…
You can add in custom properties in the OS definition segment but it wont help you with the P rating.
Thanks. In the customer properties how do we change event type from Availability to Slowdown?
Hi Chad
In the custom properties how do we change event type from availablity to slowdown. Could you please help me?
Hi Ram - How do change alerts from service availability alert to Slowdown alert for OS Services?
Hi @sundarv1 , I don’t think it is possible from Dynatrace level. I hope you can customize the event processing rule in ServiceNow to achieve it. Unfortunately, I don’t use ServiceNow. Otherwise i would’ve tested it to conform you.
If you create a custom alert by way of the metrics, you can then set the type of alert towards the bottom of the page as you set it up:
Hi Chad
How to create metric event for OS Service issues?. Could you please share some examples?.
When OS service goes down, it needs to create a slowdown metric event
So if you want to alert when an OS services isn’t available and list it as an availability issue:
Its really up to you, I would recommend tinkering around and setting it the way your organization will need it.
Currently OS Service alerts are coming as Availability event. What we are looking to create as slowdown event for our organization. Does the metric event work for OS Service?
okay, so you would select the desired metric and then classify it as slowdown in the drop down.
ok. if we do this - should we disable what we have done already in Settings - Monitoring - OS Services Monitoring?.
I would yes, because the creation of this defined alert, will be induplicate to what is out of the box by way of the OS Alert Settings.
Hi Chad
For OS Services monitoring when alerts are generated , in the dynatrace console - problem
in the impacted column - OS Service is coming, not the impacted CI. How do we get that?,
Attach is the configuration.
Sundar.v
Chad - Thanks . In the above screenshot where we are defining to send alert if OS service is not running?,
