How to specify network interfaces during Managed installation?
I’m installing a Dynatrace Managed Cluster. There are 3 network interfaces on the server and 1 must be used for users, an the other one for ActiveGates.
How can I setup them?
Hey Vincent, you’ll be prompt in the interactive mode of installer to specify a network interface. Or you can specify it via parameter in the silent mode.
--cluster-ip — If your machine has more than one network<br> interface you need to decide which network interface will be used for <br>Dynatrace Cluster traffic and put its IP4 address here.
source: Customize OneAgent installation on Windows
In case you want to configure more details on IP addresses used specifically for UI and agents it’s only available in UI - Node details page. See the screenshot:
Does it answer your question?
