Hello everyone, i have a customer that wants transform the unmonitored hosts in services, how can i do this?
How to define service from Requests to unmonitored hosts - Dynatrace Community
Slightly older community post but I think this is what you meant? ![]()
its not this but is something similar, thanks for your answer
Maybe you are looking for a Custom Device creation:
When you create a custom device informing the Unmonitored host and port (called by monitored hosts), Dynatrace will create services over this custom device and you will be able to see them in the service flow/traces.
You can see this option only after you select one of the requests as filter.
Is this what are you looking for?
