How to upload mobile applications with dsym files automatically?
Do you happen to know how mobile applications upload their dsym files? I got the indication that this isnt possible via API token and that we have to submit them manually. I think once a week for a release is already quite a lot, considering the extra work on both sides. But for test builds, we now upload them to Crashlytics every build so essentially several times per day.
Yes, it’s possible Mobile Symbolication API - PUT upload file for an app version — Dynatrace Managed Docs
You have several options: DSSClient (MacOS only), Fastlane, or API calls directly.
Here is an overview of possibilities on how tu upload and manage symbol files via UI or API:
