Based on filters you can indeed filter out metric lines based on dimension values. The instructions on the f5 page is the best one as it also has the and/or filters: F5 BIG-IP extension — Dynatrace Docs
@Mike_L,
Seems good for checking it out! Will try to post back some examples, as I’m dealing with a situation where I believe there are more than 100K interfaces…
Do you know how to exclude metrics if a field (such as if.name) is not filled in and doesn’t generate a dimension?
For now I can filter correctly if the dimension exist, but I can’t filter if the dimension does not exist.
