Kindly suggest how to use custom atuo tagging in both classic and New dashboard.
Hello @KirubakaranP . Variables will be the segment where you should be able to add in tags overall on the dashboard tiles. Otherwise, much like the classic dashboards, you’d add the tag into the payload of the metric query.
While we are on the subject, Management Zones are replaced with “Segments” Segments — Dynatrace Docs
Subject: Dashboard Tagging for PROD Promotion Status
Hi Chad,
Thank you for your response.
I have a use case where I need to define a tag on each new-style dashboard to indicate whether it has been promoted to PROD or not. Based on your previous answer, could you kindly explain how you would approach this?
Ultimately, my goal is to build a dashboard that displays the promotion status of other dashboards (i.e. PROD vs. non-PROD). To achieve this, I need to understand:
- Which API endpoint I should use to add a tag to a new-style dashboard.
- Whether it’s possible to update the status dynamically using the API.
Could you please provide a concrete example to illustrate the steps?
Kind regards,
Marwan
