In my workflow
Task_1 is DQL type task which might have null values in output , like given below
“name” : “ABC”,
“age”: 10,
“height”: 6
or
“name” : “ABC”,
“age”: 10,
“height”: null
I would like to run next task only if height value is no null
How Can I write condition ??
Thanks in advance
Heramb
any help would be appreciated .
On the next task, under conditions, try something like this:
{{ result(“Task_1”).records[0].height != None}}
Change “Task_1” if that’s not the correct name of the DQL task.
Here are some links that might be useful for you:
Please let me know if I can help you further.
