i want to know if Dynatrace logs the http request headers ? (i know it can log the span and trace ID even if log monitoring feature is not activated)
Thanks.
Thanks.
Hi @salah ,
You can configure Dynatrace to log specific http-headers if you have full-stack monitoring of a webcomponent and configure the http-header in the `request attributes` section in the settings.
In this scenario, the header will become available on purepath level; if you want to have it available on RUM level, you have to make an additional configuration in the Application definition.
