Hi Community,
every day we receive many of these exact problems in our Slack channel that resolve in about a minute. Is there any option to do not show these notification when they are resolved so quickly?
I recommend changing your outage handling settings in the HTTP monitors to be less sensitive. There are options to trigger the outage alert after 1,2,3 or 5 failures and you can set this either per monitor or at the environment level. There is more information here
Ah, ok. You don’t have permissions to update this for the environment. You’ll either need to ask someone with those permissions to do it or update the monitors that are most regularly triggering these alerts.
Create alerting profiles and fine tune your alerts notification based on alerting profiles. refer this blog
