HTTP Monitors: AWS Signature authorization
I would like to create a HTTP Monitor to make a GET requests and validate some content answer.
If I use postman, authorization is done here:
I was checking Supported authentication methods in Synthetic Monitoring but I cannot see it. Do you know how to input that information creating a HTTP Monitor?
Thank you!
Best regards
Hi Anton,
I’m not aware of any way to do this OOTB. So I think you would need to calculate it in a pre-execution script. I found some information on this here and here.
I haven’t seen this request before but if you think others might also want it added to the product in a future release, I would add a Product Idea,  so others can vote for it, if interested, and the PM can consider it. Thanks
Thank you!
I have just raised this product idea.
Best regards
