HTTP response in alerting notification body
I want to add the HTTP response and error code in Dynatrace alerting notification body but I only get the failure rate increase. The placeholders I have used are the {ProblemDetailsJSON} and {ProblemDetailsJSONv2}. Also, I have overridden the default failure detection parameters, so that I catch 500-599 server errors. Is there any way to do it?
Dynatrace Agent One version: 1.263.138.20230405-022541
Dynatrace Version: 1.266.100.20230510-201314
Not that I am aware of unless you can target the data as a request attribute, but even if you could, i don’t think you can post the Attributes as a placeholder for the alert payload.
