I can't no longer create/delete a section on a custom dashboard
Is this an admin setting or version of the software?
I used to be able to add or delete a section on a custom dashboard. but all of a sudden I don’t see section option. what is the cause for this?
Hi Richard,
There have been some updates to custom dashboards in Dynatrace. You can now click and drag your mouse to select multiple tiles. You will see the option to delete the tiles selected. Also there is the new header tile under Custom charts in the Tile Catalog (i.e. when you click Add tile). This is equivalent to the old section header. Please see the following blogs where the dashboard enhancements were announced and also the forum where dashboard enhancements are discussed below
Blog - https://www.dynatrace.com/news/blog/author/roman-w…
Forum - https://community.dynatrace.com/spaces/483/dynatrace…
NJ
Current information about dashboard and charts are available on the documentation site:
How to exactly pin tiles you will find under the link:
