IBM datapower monitoring
We installed IBM datapower on an EKS cluster; we are currently monitoring infrastructure metrics (cluster, node, namespaces, workload) using dynatrace operator
However services data are available only for few services and traces are not showing data even if I can see link between processes that calls and are called by IBM datapower
Is the IBM Datapower extension needed in order to have a complete visibility on IBM datapower?
Is possible with IBM Datapower extension installed to have performance data on missing services?
i have the IBM DataPower installed, its very useful for the below metrics
also, you can enable the below out of the box alerts from the anomaly detection settings
And what about services data?
Are you able to track real requests? We only have a few services and some of them are opaque
Dynatrace pop up message is pointing you to OneAgent SDK.
Best regards
DataPower does seem to have a built-in OpenTelemetry integration:
OpenTelemetry integration - IBM Documentation
I just found this myself, so I don’t know how well it works, but I don’t see why this wouldn’t work with Dynatrace, since Dynatrace fully supports OpenTelemetry and the traces/spans should be distributed with other Up/Down stream traces, even if they are generated by OneAgent.
As I stated in my other reply in this thread, DataPower does have a built-in OpenTelemetry exporter and sampler that you can activate on the appliances.
One problem we’ve discovered with it though is that it doesn’t seem to propagate context if it receives a request that already has OTEL trace data in it.
A lot of our API requests go through two DataPowers.  An external one that sits in our DMZ and an internal one that does some transformations.  We’ve insured that the traceparent and tracestate headers are getting propogated through them and, when we see the OTEL traces from the internal appliance, we see the traceparent header with the correct trace id from the external appliance where the request originally came in, but for some reason DataPower still creates a whole new trace id on the internal one.  It makes no sense.  We put a support case in with DataPower.  We’ll see how it goes.
Hey @36Krazyfists did you ever got any info back from IBM? We notice the same, setting all transactions as root_span: true.
Could you fix it?
So, it actually does work great!  There is one specific gateway that it isn’t working on, but I discovered it’s because of the transforms that are occurring within that particular DataPower Gateway.  That gateway takes HTTP API requests and transforms them to JMS messages to be transmitted to a Tibco EMS broker.  That transformation breaks the OTEL chain (although, I’m trying to convince the DataPower engineer to take the traceparent header key and value and place them in the JMS message and I think Dynatrace will properly propagate the context if he does that, but so far he hasn’t tried it…).
But yeah, for all of our other gateways, it works awesome and context propagation works wonderful!  It’s pretty sweet no longer being blind within DataPower!
I have a question: in my organization, we’re experiencing an issue where W3C (traceparent, tracestate) and x-dynatrace headers are not being propagated through API Connect to the backend services.
Have you encountered something similar in your setup?
I’m not familiar with API Connect, sorry.
But I can tell you this.  OpenTelemetry will only propagate the W3C headers (traceparent, tracestate, etc…).  The Dynatrace specific stuff can be forwarded on by specifying custom headers that need to be forwarded (in Datapower’s OTEL configuration that is an option.  Not sure how API Connect differs).  However, some of Dynatrace’s headers/cookies for tracing may require iteration on the data and, because the Dynatrace-specific headers are proprietary, those iterations can only be handled by OneAgent (or OneAgent SDK).
Point being, W3C compliant headers should properly get propagated by a correctly configured OTEL configuration, but Dynatrace-specific headers can only be forwarded as is and thus no trace data would get reported about them if they don’t use the W3C headers to report.
Hi @36Krazyfists,
Can you please elaborate more about OTEL Config for Dynatrace headers that you have in your Datapower?
Best Regards,
Patryk
Hi @36Krazyfists,
We are facing the same issue with a standard HTTP-to-HTTP flow in IBM API Connect/DataPower native OpenTelemetry.
Our OneAgent-instrumented upstream MFP application sends a valid W3C traceparent to DataPower. DataPower receives it and we can see its value as a span attribute.
However, DataPower exports the server span as a new root trace:
Inbound traceparent trace ID: 4df28fd6c72fb0d15dd14d3974872ed3
DataPower receives this W3C header: traceparent: 00-4df28fd6c72fb0d15dd14d3974872ed3-178d7281f230df6a-01
DataPower exported trace ID: 4ba1be2592378dbd9e781c4fa543d719
DataPower attributes:
request.is_root_span = true
transaction.is_root_span = true
We use CP4I with DataPower API Gateway 10.6.0.8, native OTel export via OTLP/gRPC to an in-cluster Collector, and then OTLP/HTTP to Dynatrace Managed.
You mentioned that context propagation now works well for your normal HTTP gateways. Did IBM provide a fix, a required configuration change, or a DataPower version recommendation that made DataPower adopt the inbound W3C traceparent instead of creating a new root trace?
Any details would be greatly appreciated. Thank you!
Best Regards
Patryk
