Dear All,
We intend to monitor the queue managers using the local (OneAgent) deployment extension. What is the anticipated memory overhead for each queue manager on the monitoring host? Additionally, should we expect any latency with this method?
Babar Qayyum
Hi @Babar_Qayyum
Memory overhead
I’ve used this setup on one of my projects, where I saw roughly 50–100 MB per queue manage. Actual usage can vary with the number of queues and channels.
For reference, OneAgent extension limits list 100 MB RAM per instance on the default profile and 200 MB on High limits. The combined hard limit for all data sources is 15% RAM by default and 25% on High limits.
Latency
In my experience, local (OneAgent) deployment adds negligible latency. The extension runs on the same host as the queue manager, so there are no network round trips between them.
Sujit
Hello @sujit_k_singh
I appreciate you sharing your personal experience. Did you implement local (OneAgent) deployment solely for the queue managers part of the IIB, or did you also include the IBM MQ Hub?
Babar Qayyum
Hi @Babar_Qayyum
I used local (OneAgent) deployment only for the queue managers that are part of IIB. I didn’t include the IBM MQ Hub.
Sujit
