IBM MQ extension
I was trying to enable IBM MQ monitoring from using plugin extensions v2, but I noticed new plugin does not have the option “Run Reset Stats on Queues (retrieves Deq/Enq)”.
Is there any other way to disable Reset Stats in IBM MQ monitoring extensions 2.0 plugin?
Hi, when creating the monitoring configuration you can disable the “Queues - Enqueue/Dequeue” feature set to disable resetting the statistics.
Hmm.  I don’t see that option.  Could you post a picture?  Thanks.
It is on the second screen, like this one (a different extension, but this screen is identical just with other feature sets).
Thank you!
Disabling the option Queues - Enqueue/Dequeue (2) did the job.
Now I see reset_q_stats’: ‘false’ in the json config payload.
