IBM MQ failed to assign monitoring configuration
Dear team,
While configuring new monitoring configuration getting below mentioned error.
How will fix this issue and why we are getting this error can you please help us?
Dharmender
Maybe you can configure another performace profile in the EEC.
Best regards
Hi Dharmender,
Like Anton explained, ActiveGates can run on different profiles, each one allows more consumption of resources. You are hitting that soft limit on resources on your ActiveGate.
You can also run your monitoring configuration on another ActiveGate group, or split the number of endpoints in your monitoring configuration across other monitoring configurations and split those on different ActiveGate groups, that way you are load-balancing.
Diego
