Hi community
I drawing diagrams in PowerPoint/Visio/Lucid for customers and I would like some good looking icons of ActiveGate, Managed Cluster, OneAgents, Extensions etc.
I have found icons in the developer pages and a project called Barista, but this is not what I’m looking for. Are you aware of vector pictures or stencils used for marketing or architect tasks?
I am using default search engine images section, where you can apply filters about form, size, backgroup color, etc.
Normal filters in google.com or duckduckgo.com were sufficient normally.
Best regards
Hi !
I hope this helpfull , someone have similar question
Solved: Downloading Dynatrace Icons - Dynatrace Community
Also you can use Vectorizer – Free Image Vectorization , for vector graphics
I hope its helpful
Hi Pierre
Thank you f ro the comment.
I also found that link before submitting the ticket. As it also didn’t solve Marinas problem it doesn’t solve mine
I will look at Vectorizer, but leave the Q open.
I am also looking for this.
a visio stencil and draw.io shape library would be very helpfull in creating proper dynatrace designs.
