Hey,
I have enabled VMWARE Integration in our tenant.
I would like to Implement alerting for power, cooling, and RAID failures on ESX hosts, how to do that ?
I see very limited metrics for esxi hosts with native integration and also explored metrics of VMWARE remote monitoring extension, but I could only find vmware.vm.power.status metric which tells the power status.
How can we implement this ? any thoughts ?
Hello @MohammedRahman
You can use different approaches:
- OneAgent Metric Ingestion (Recommended)
The simplest approach if OneAgent is deployed on your VMware hosts.
Local HTTP Endpoint
Push custom metrics directly from the host using the OneAgent ingestion endpoint:
http://localhost:14499/metrics/ingest
Payload
vmware.cooling.usage,dt.entity.host=HOST-XXXXXXXX gauge,85.3
Use a declarative YAML-based extension to pull additional VMware metrics via VMware APIs (e.g., vSphere SDK).
Metrics API v2 (Remote Ingestion)
If OneAgent is not on the host, push metrics remotely via the REST API:
POST https://{your-environment}.live.dynatrace.com/api/v2/metrics/ingest
