I would like to see how both the service flow and distributed trace look in a cross-environment.
I need a full capabilities list:
- If the drill-down capability is full in a cross-environment.
- If an entire service-flow view is possible, or if the service flow is fragmented; the same with the distributed trace.
If I get redirected to another dynatrace environment, can I come back again to same when reverse traced.
I’m unsure about this, but if you configured a connection to the remote environment and you can’t see requests on it, you can trigger a manual search for the trace in configured environments. In the upper-right corner of the trace page, select Find in remote environments.
