I’ve not used AppMon, but from what I can see from the pictures, in previous product the PurePath contained all the methods in the call line by line.
In Dynatrace we can only see the service entry point and sampled method hotspots.
What do you think is the main reason for Dynatrace to stop supporting this feature? And can you give me some suggestions about how you guys analyze the whole call stack without adding every single method as a Custom Service? Maybe another tool or a technique I am not aware of?
I am not sure whether I understood your question correctly, but the method hotspots information can be taken from the following location of every process and service as well.
“Code level” of PurePath view. To me this is the correct answer. In Dynatrace, on-hover of the code-level, you’ll see more information if it’s required too. This is not unlike AppMon (webUI view of PurePaths).
You could enhance your diagnostics with method hotspots, as Babar answered. Or even with the response time hotspots view.
For example, there is a PHP PurePath below. I know that there are some methods which runs to do some internal executings then connect to mysql and fetch the data, but I can’t see them in the code level.
It only shows that mysqli_connect & mysqli_query. There should be bunch of executed functions but I can’t see them here. The only way I know is to define Custom Service to catch these methods.
Is there a complimentary tool to use with Dynatrace if I see that mysqli_connect took a long time, so I can dig in deeper to every single function/method that is executed and check their individual performance?
