Infrastructure Monitoring of IBM, Oracle, Dell and VPlex platforms
Has anyone been able to achieve monitoring the below platform Infrastructure? We have an interested client.
Please provide possible options and details.
IBM Power Series
Oracle Exadata
Oracle Exalytics
Oracle Exalogic
Dell EMC VxRail
Dell EMC VxBlock
Dell EMC Unity/VMAX/PowerMax Storage
VCenter
VPLEX
Hi @echwallah ,
I have only experince with VCenter.
Set up virtualization monitoring | Dynatrace Docs
Best regards,
Mizső
The Oracle Exadata, ExaLogic, Exalytics are appliances. The OS on the later versions is Oracle Linux, so in theory Dynatrace could monitor these appliances on infrastructure only mode, however, you are not allowed to install non-Oracle software on these devices.
VxRail and VxBlock can be monitored through Vsphere as these packaged devices have this prebuilt. Then the VM’s can still have the OneAgent deployed.
IBM Power Series (PPCLE) is supported from a OneAgent OS level installation (with supported Linux distros) for physical infrastructure monitoring, it might be worth creating specialised scripts that pipe information to the OneAgent with |dtingest.
Storage arrays like Unity would need a custom extension built to pull metrics from the device, depending on the interfaces available for the device (SNMP, API’s, etc.)
Raised an RFE for EMC Unity: https://community.dynatrace.com/t5/Product-ideas/Enhancing-Storage-Observability-for-EMC-Unity/idi-p/300466
