Looking to see if anyone has a working use case of ingesting AWS x-ray data as traces into Dynatrace. In theory, x-ray can be fed to an ADOT collector, that can then forward the data in OLTP to Dynatrace. Not sure how the trace data would work interact with the Dynatrace entities and/or AWS Cloudwatch connector data sets.
Hey @ronmacdonald ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
At this point I’m just trying to understand the possible benefits of bringing the x-ray data into Dyantrace. I know there is a design to forward x-ray to ADOT, then forward those to Dynatrace as OTEL. Just not sure if it’s worth the work. Are there certain AWS services or designs that would benefit most?
