Hello guys!
How are you all?
So, I’m with an interesting problem… Let me introduce you to the context.
I developed a Custom Synthetic Application using the Dynatrace Toolkit, and it worked perfectly on one of ours Tenants (We’ve two PT and BR).
And for my surprise, I changed all the Tokens and Environment URLs to the correct ones, on dev mode the App runs well, I performed the Deploy and it makes with no problem. But when we try to open the App via Tenant, it stays on infinite loading, like if there’s no response from the API (It’s called via App Functions to the Dynatrace APIs following the docs). I’ve checked all the Tokens permissions and User Permissions; the permissions and Policies are the same in both.
The main question here is, why it works only in one if it’s all the same config in both? Maybe some environment config? :thinking:
Kinda regards,
Maximiliano Lopes
